too hot
Old Jun 26, 2006 | 10:03 PM
skunk's Avatar
skunk
Default too hot
I cant seem to keep my car cool it's fine for about half a hour then it slowly gets above normal and the only way it stops geting hotter is to turn on the heater I am runing mostly water
Old Jun 26, 2006 | 10:09 PM
sprostang's Avatar
sprostang
I ♥ Acer
Default RE: too hot
Change the stat, run 50/50 and it should be fine.
Old Jun 26, 2006 | 10:24 PM
skunk's Avatar
skunk
Default RE: too hot
I have a 180
Old Jun 26, 2006 | 10:28 PM
sprostang's Avatar
sprostang
I ♥ Acer
Default RE: too hot
How old is it?
Old Jun 26, 2006 | 10:32 PM
1BIGMOFO's Avatar
1BIGMOFO
Default RE: too hot
drain it all out and pull the res out and clean it all out.... did you ever have a leak and just keep adding water? sounds like you need to run 50/50 and mabe even some of that super cool stuff from advance auto parts..
Old Jun 26, 2006 | 10:34 PM
skunk's Avatar
skunk
Default RE: too hot
maby 6 month it has that super cool stuff in it now
Old Jun 26, 2006 | 10:37 PM
sanitarium16's Avatar
sanitarium16
Default RE: too hot
There is probably air in the system.
Old Jun 26, 2006 | 10:43 PM
sprostang's Avatar
sprostang
I ♥ Acer
Default RE: too hot
ORIGINAL: skunk
Drain it and fill it with 50/50 and go from there.
Old Jun 26, 2006 | 10:45 PM
skunk's Avatar
skunk
Default RE: too hot
what kind of a air problem
Old Jun 26, 2006 | 10:57 PM
Bozz's Avatar
Bozz
Default RE: too hot
Have you checked your water pump? Make sure the the bottom of it is dry after running it. I had that happen in my 87' and my diaphram in my water pump was slowly rupturing. Until D-day hit. Not fun to see steam coming out of the hood.
