cooling fans
Old Jun 27, 2006 | 01:14 PM
Scooterman's Avatar
Scooterman
Default cooling fans
what is the differnce between a electric fan and a fan clutch, i no one of them mounts onto the radiator and the other would hook onto the water pump which is the one i am looking for, but im just confused on what i would need
Old Jun 27, 2006 | 01:18 PM
P Zero's Avatar
P Zero
Default RE: cooling fans
A fan clutch has a thermal spring built in to the front of it. When the engine reaches a certain temp the spring deforms and engages the fan. An electric fan is just that, it usually mounts to the radiator and is controlled by a temp sensor usually built into a coolant passage somewhere.
-P.
Old Jun 27, 2006 | 01:23 PM
Scooterman's Avatar
Scooterman
ok then i must be real confused then, right now i have a radiator fan.. but my friend tells me its not the right fan, he told me to get a fan that runs off of the water pump, mechanical fan perhaps? but im just confused on hwat i need to get, b/c i thought a fan clutch runs off the water which i y i thought i needed to get one..
BOB ROME
Jul 26, 2023 01:54 PM
PaulH2
20
Jan 31, 2016 09:48 AM
Seanam
Oct 4, 2015 10:15 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
Sep 25, 2015 09:06 AM
