rear end
Old Jun 29, 2006 | 07:17 AM
object13's Avatar
object13
Default rear end
i was wondering, because i'm possibly buying a 5.0 thunderbird(86, its for the engine, 500ish if i buy it) it comes with a posi rear end, so i was hoping i could use the rear end on my 66 mustang, i'm doing a 5.0 t-5 conversion on it. So i thought, hey score a rear end along with an engine...can anyone help me out here?
Old Jun 29, 2006 | 06:09 PM
4Stangs's Avatar
4Stangs
Default RE: rear end
Your 66 mustang has leaf springs and the thunderbird has coil springs with upper and lower control arms. I assume it's a turbo coupe since the 8.8 you speak of is limited slip?. My point is that the 8.8 won't have spring pads but WILL have a bunch of stuff you don't need. If it's a out of a turbo coupe it may (not sure) also have rear disc brakes.
You'll have to consider the work involved, added parts you'll have to buy to get this rear to work etc. (A custom driveshaft will be a given either way) If the rear in your 66 is a nine inch, you'd be better off putting a limited slip unit in it and forgetting about the 8.8 conversion IMO.
Old Jun 29, 2006 | 06:11 PM
4Stangs's Avatar
4Stangs
you said 5.0 thunderbird, so probaqbly no rear discs.
mtgldr
Feb 3, 2024 09:00 PM
zsmart
Convertible Tech
Feb 29, 2016 08:33 AM
Ryan Fitzpatrick
Sep 14, 2015 02:21 AM
fastbackford351
Sep 12, 2015 09:42 AM
Dragonus18
Sep 9, 2015 01:21 AM
