plz help spring problem
Old May 11, 2004 | 04:23 PM
efeezy's Avatar
efeezy
Default plz help spring problem
In dec i got the matrix lowering springs installed on my 97gt. The springs were a 2 inch drop and it looks like they might have went a bit lower then that in the front. When im driving down the road and i hit the slitest bump my wheel alway bangs off the wheel well on the driver side. If i look there is only like a inch gap between the tire and the wheel well and were the tire hit is where the fuse box is fourmed out in the wheel well. What can i do are the springs cheap springs and i need new ones or is the car just too low and i should put differant springs in there?
Old May 13, 2004 | 12:51 AM
VertStangGT86's Avatar
VertStangGT86
Default RE: plz help spring problem
Do you have stock rims on it? Don't know about matrix, they seem kinda cheap though. Also if you're doing a 2 inch drop you should have casper/camber plates and/or a bumpsteer kit.
Old May 13, 2004 | 01:08 AM
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
were the spring isolators removed from your stock springs and put on the aftermarket ones you put on? Were they both put back on? you'll get about 1/4 in per each isolator (top and bottom) thats installed. If you dont have any on then you should get some, it will get you back up.
Old May 15, 2004 | 06:49 PM
efeezy's Avatar
efeezy
ya i have the stock rims on my car now. The matrix springs were kinda cheap mabe thats why im having problems. I dont know if the springs isoloator were put back on ill have to ask the garage which put them in for me.
Old May 16, 2004 | 02:46 AM
VertStangGT86
You should be able to look and see, they're rubber that sit between the control arm and spring on the bottom. Should be some kinda sleeze on top.
PullTab
Oct 30, 2015 08:46 AM
robjh22
Suspension
Sep 8, 2015 12:47 PM
Sep 8, 2015 11:50 AM
Sep 1, 2015 08:16 PM
