Vibration with automatic
Old Jun 12, 2003 | 11:03 PM
couldabin's Avatar
couldabin
Default Vibration with automatic
Hi,</P>
My 1998 Mustang has a vibration that occurs for two or three seconds when shifting under light acceleration at speeds of around 35-45 mph. It almost feels like the car is travelling over washboards.</P>
Any thoughts on what is causing it?</P>
Thanks.</P>
Old Jun 13, 2003 | 12:46 PM
converted's Avatar
converted
The car doesn't have major clunking when going from reverse to a forward gear does it?
Old Jun 13, 2003 | 12:53 PM
couldabin's Avatar
couldabin
Nope. That part feels pretty normal.
Old Jun 13, 2003 | 06:18 PM
converted's Avatar
converted
You haven't had any work done on the drivetrain recently have you?
Old Jun 13, 2003 | 06:34 PM
couldabin's Avatar
couldabin
None. I found a service bulletin for mid-90s Mustangs (among other Fords) that described the symptoms perfectly, and it said degradation of the transmission fluid could cause it. I was just wondering if this is a known issue.
Old Jun 13, 2003 | 06:42 PM
converted's Avatar
converted
I guess it could be. Every auto mustang I have had got a trans swap quickly. I never was a big fan of the AOD. Not when I have a C4 laying around anyways.
Old Jun 13, 2003 | 11:09 PM
makarovboy's Avatar
makarovboy
Replace the tranny fluid. If this doesn't get rid of the problem, I would also look at the flex plate, torque converter set up. A bent flex plate/loose converter will cause this also. You don't want that coming apart at highway speeds.
Old Jun 14, 2003 | 06:57 AM
couldabin's Avatar
couldabin
Thanks for the advice!</P>
<IMG src=smileys/smiley2.gif border="0"></P>
b8checker
Oct 8, 2015 12:55 PM
guitarman376
Sep 30, 2015 05:54 PM
b8checker
Sep 30, 2015 07:11 AM
wraith777
Sep 28, 2015 10:49 AM
treesloth
Sep 28, 2015 07:03 AM
