Bad vapor valve?
Old Jul 21, 2006 | 09:42 PM
Cletus's Avatar
Cletus
Default Bad vapor valve?
In response to my fuel tank overpressurizing and pushing gas out the (new) cap, I am replacing the charcoal canister and all of the rotting vacuum tubing connecting it to the purge valve and intake. When I removed the lines, I found that I could not blow or suck air through the vapor valve on the tank. Should I be able to? I am planning on putting a vacuum tester on the valve after removing the gas cap, but I am not sure what it should hold.
Any help is appreciated. -Cletus
Forgot to add that it is on a 93 GT.
Old Jul 23, 2006 | 01:14 AM
Cletus's Avatar
Cletus
Default RE: Bad vapor valve?
Update: When I dropped the gas tank to replace the valve, I found the rubber line connected to the valve had been pinched between the tank and the trunk floor-pan. New line, problem solved!
GimpyHSHS
19
Dec 19, 2023 01:12 PM
mrtrodonet
Sep 19, 2020 03:12 PM
Dathan
Oct 5, 2015 05:52 AM
KingRando
Oct 2, 2015 08:06 AM
UrS4
Sep 30, 2015 10:13 AM
