question about reverse
Old Jul 26, 2006 | 02:37 AM
MustangGTxx35th's Avatar
MustangGTxx35th
Default question about reverse
i have a 94 dodge caravan (i kno lame) and it has an auto transmission and it shifts fine into drive and park and everyone but reverse. whenever i put it in reverse it locks in but dosent lock in it sits for awhile then makes a horrible noise and jumps into reverse. anything would help.
Old Jul 26, 2006 | 11:48 AM
sandcracker21's Avatar
sandcracker21
Default RE: question about reverse
i think u mean reverse?
sounds like ur tranny is goin south
Old Jul 26, 2006 | 12:06 PM
99saleen351r's Avatar
99saleen351r
Could be halfway in between gears
Old Jul 26, 2006 | 12:19 PM
sandcracker21
that happens on my escort ALL OF THE TIME
i havta have it half way between for it to work
Old Jul 26, 2006 | 12:31 PM
Chopper's Avatar
Chopper
The cable could need to be adjusted.This cable is underneath the battery and the battery,battery tray,and airbox has to come out.To adjust the cable you place the shift lever in "park".Loosen the clamp and pull the cable tight.Now tighten the clamp.
If this doesn't fix the trouble here's a link.
http://www.dodgeforum.com/Default.asp?
BTW.Mrs.Chopper has a Dodge Caravan that I drive to keep from running my Mustang into the ground,and no it's NOT lame!!!
Old Jul 26, 2006 | 04:03 PM
MustangGTxx35th
HaHA thanks for the help. and i did mean reverse
Old Jul 26, 2006 | 04:18 PM
MikeHawke's Avatar
MikeHawke
Retired MF Moderator
could be the shift linkage needs adjustment......something like chopper was saying.
Old Jul 26, 2006 | 11:38 PM
MustangGTxx35th
well i found out it has another problem. a broken motor mount thats also somewhat holding up the tranny. AND on top of that all the bolts holding the tranny to the engine but 2 are missing! its really sagging...
GimpyHSHS
19
Dec 19, 2023 01:12 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
