Mr. Clean Autodry
Old Jun 1, 2004 | 04:21 PM
propellerhead's Avatar
propellerhead
Default RE: Mr. Clean Autodry
Some of the $0.25 car washes have a "spot free rinse" cycle. Same thing. Soft water.
I hope you get more than one use on that $20.
Old Jun 1, 2004 | 04:33 PM
Sidewayz6.0's Avatar
Sidewayz6.0
With the initial filter you get 3 washes, but the replacement filter get you 10 or something. It's a little scam they've got going on, but it works really well. So it's worth it.
Old Jun 1, 2004 | 04:55 PM
propellerhead
If the filter on those is just like the one in a water softener for a house, then you might try soaking and rinsing it in water with salt. In home water softeners, salt is used to breakdown and rinse away the minerals that the filter collected. It's like recharging your K&N.
Old Jun 1, 2004 | 05:09 PM
Sidewayz6.0
Thats actually not how a water softener works, there aren't any filters in a water softener. Water passing through the mineral tank loses positively charged calcium and magnesium ions to negatively charged plastic beads. The salt in the brine tank is used to clean the mineral deposits off of the plastic resin. What actually makes the water soft is the minerals being removed from the water itself.
In the auto dry...The filter is a reverse osmosis system. Which is a lot harder to explain, but the bottom line is don't clean the filter with salt. It can't be cleaned, and you'd just be spraying salt water all over your car.
Old Jun 1, 2004 | 08:47 PM
VertStangGT86's Avatar
VertStangGT86
I know multiple people that really like it, I've thought about getting one too.
Old Jun 1, 2004 | 09:06 PM
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
ORIGINAL: sidewayz4.6
Why thank you Dr. Sidewayz
Old Jun 1, 2004 | 09:32 PM
Steuben02's Avatar
Steuben02
Well, I think I'm definetally gonna have to try it. It would have to work pretty darn good for me to make the switch, because personally I don't find drying the car myself to be too big of a pain in the ****. I use a thing called the 'California water blade', which is a squeege-type thing with a purple handle and soft plastic tip that wicks the water away from the car. It works great.
Old Jun 1, 2004 | 11:50 PM
VertStangGT86
I just usually use the eagle one wet wax and dry with my chamie (know that's not how you spell it but drawing a blank) so I havn't gotten around to using it yet.
Old Jun 2, 2004 | 01:07 AM
Dan04COBRA's Avatar
Dan04COBRA
I use regular car wash and this super-absorbant towel thing, I can dry my entire car perfectly before i need to wring it out.
Old Jun 2, 2004 | 02:08 AM
Sidewayz6.0
I do what I can...[sm=smiley2.gif]
