17" vs 18" wheels
Old Aug 6, 2006 | 10:51 PM
Durr727's Avatar
Durr727
Default 17" vs 18" wheels
Hey I'm soon going to be in possession of some 18" saleens and just wanted to know what are the performance/gas mileage etc effects if there are any. thanks.
Old Aug 7, 2006 | 12:01 AM
samseed101's Avatar
samseed101
Default RE: 17" vs 18" wheels
What is your current tire circumference vs. the newer one? You can actually have 17" rims with tires that has the same circumference as 18" rims with different tires.
Old Aug 7, 2006 | 12:12 AM
Durr727's Avatar
Durr727
there 245-35-17 i think
Old Aug 7, 2006 | 12:48 AM
samseed101's Avatar
samseed101
ORIGINAL: Durr727
That would mean that your tire's diameter is 23.752 inches. Do you know what the other tires would be for size (on the 18's?) Once we have both numbers, you can figure out which will give better gas mileage, etc.
Old Aug 7, 2006 | 01:07 AM
OnyxCobra's Avatar
OnyxCobra
245/35 is a low profile, it should be 245/45 for our stangs.
Old Aug 7, 2006 | 01:49 AM
samseed101's Avatar
samseed101
ORIGINAL: OnyxCobra
That would make the diameter 25.681
Old Aug 7, 2006 | 03:29 AM
Twister's Avatar
Twister
ok, here is the truth, with tires that have the same circumfrence, the 18 inch wheel will produce better cornering speeds and G loading in cornering on a smooth surface due to less sidewall flex. A 17 inch wheel also provide very good cornering speeds and G loading, but on a street, due to sidewall flex will provide a smoother ride since the tire is the first part of the suspension.
Old Aug 7, 2006 | 04:02 PM
Durr727's Avatar
Durr727
OK here's the right numbers...
17" : 245/45-17
18" : 265/35-18
There we go, so will there be any performance/mileage changes etc...
(thanks twister for the info)
Old Aug 7, 2006 | 04:06 PM
Twister's Avatar
Twister
your 60 foot times will also drop due to less mechanical grip
Old Aug 7, 2006 | 04:10 PM
Durr727's Avatar
Durr727
and i also heard that with bigger wheels you get a higher top speed but lower acceleration.
