Power window problems???
Old Jun 17, 2004 | 09:39 PM
RedStangGT2000's Avatar
RedStangGT2000
Default Power window problems???
Just went to pull my GT into the garage and the drivers side window won't go up. Has anyone had this problem? am I going to have to take the door apart? The passanger side is fine and they both worked minutes before my only hope is that their on different fuses (highley doubtful) If you have any info please let me know I don't want to take my door apart if I don't have too.
Anyone know the cost of a new motor and the difficulty of instalation if need be?
Thanks, RedStang
Old Jun 17, 2004 | 09:52 PM
Obsol3te's Avatar
Obsol3te
Default RE: Power window problems???
Just go to a junkyard and pull one for a couple bux, itll be cheap but it also may not work
Old Jun 18, 2004 | 03:15 AM
JustinBHR's Avatar
JustinBHR
my driver side window stops working intermittantly, if i give the door panel a good hit it will usually go up.
Old Jun 18, 2004 | 05:13 AM
e40water's Avatar
e40water
9/10 its youre switch that screws up, The only way you power window motor goe's is if it get exposed to alot of water.
Old Jun 25, 2004 | 09:49 PM
RedStangGT2000
Its the Motor I took it in and its going to cost 381 bucks if I have them do it.
Old Jun 25, 2004 | 10:40 PM
vfast's Avatar
vfast
I ♥ Acer
you can buy new motors on e-bay for like 50.00-100.00..no need to go to the dealer....about an hour job
NorthAmericanTuning
Nov 9, 2016 11:45 AM
NorthAmericanTuning
Mar 18, 2016 11:21 AM
JonnyBlazeGT
Nov 3, 2015 01:10 AM
movielover40
Aug 27, 2015 10:13 PM
HorsePower99
Aug 26, 2015 11:29 PM
