air cond. trouble
Old Aug 20, 2006 | 11:56 PM
moenant's Avatar
moenant
Default air cond. trouble
hooked up a/c now car overheats any suggestions
Old Aug 21, 2006 | 12:02 AM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Default RE: air cond. trouble
More info might help. Type of car, what was done, what it's doing and when. Help us help you!!!
Old Aug 21, 2006 | 12:14 AM
moenant's Avatar
moenant
95 stang 5.0 put in new compressor, condensor, water pump alternator,but it over heats what could be causing that??
Old Aug 21, 2006 | 12:23 AM
moenant's Avatar
moenant
95 stang put new compressor, condenser, water pump, alternator and it over heats while driving
Old Aug 21, 2006 | 12:54 AM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Have you checked to see that there is enough coolant in the radiator and there is not an air pocket in the cooling system? Is the a/c working now?
Old Aug 21, 2006 | 01:04 AM
moenant's Avatar
moenant
ac is working. there is coolant
Old Aug 21, 2006 | 01:13 AM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Maybe it needs a t-stat . Is the rad fan working?
Old Aug 21, 2006 | 04:35 PM
xzo6's Avatar
xzo6
I think that since there was an installation of a Condensor(in front of your Rad),you are impairing the airflow to your cooling system.Did this car come with A/C from the factory?Now you may require a larger(double or triple core Rad).The fans may also be an issue.Give us as much data as you can,because it helps.Since it is a 95 Stang I would say change out the rad (if it is 11 years old),and see if that brings your temp. down. Put in a cooler thermostat while you are at it.Obviously your cooling system can be improved upon.
Old Aug 21, 2006 | 05:03 PM
Cobrakev's Avatar
Cobrakev
Did you get the correct rotation water pump? If may have the wrong pump, which is now turning backwards.
Kev
Old Aug 21, 2006 | 06:48 PM
moenant's Avatar
moenant
i put a new t-stat and how can i be sure if it is the rad? yes it did have ac but the compressor was no good. im at a loss what more can i say as far as info?? as far as the waterpump goes i 've got it going counter clockwise.
