how do you adjust valves
Old Sep 12, 2006 | 12:11 AM
jts302's Avatar
jts302
Default how do you adjust valves
i have a classic mustang and was wondering how you adjust the valves after putting new heads on?
Old Sep 12, 2006 | 12:56 AM
Colorado_Mustang's Avatar
Colorado_Mustang
Default RE: how do you adjust valves
Hydraulic or mechanical cam? Do you have screw in studs? Stock rockers? Rail type or stud type?
In a nutshell: For a mechanical cam, look up the lash spec for hot and cold (usually only given for hot). Rotate the engine so that the camlobe for the rocker to be adjusted is on the base circle 180* from high lift. Tighten the rocker until the lash spec is met and lock in place. Tighter will result in valvetrain damage and poor performance. Too loose leads to more noise and lower performance.
For a hydraulic cam, position the engine as above. Tighten the rocker until there is zero lash. Turn the rocker nut down another 1/2 turn and lock in place.
For stock setups, look up the torque specifications and tighten 'em down. It's 15-20lb-ft for a 302.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
cr620
Oct 3, 2022 10:18 PM
mrtrodonet
Sep 19, 2020 03:12 PM
UrS4
Oct 3, 2015 06:23 AM
winner99
Sep 30, 2015 07:04 PM
