66' cruise o matic question
Old Sep 14, 2006 | 12:00 AM
jsalomone's Avatar
jsalomone
Default 66' cruise o matic question
I just purchased my first mustang.....a 66' convertable (6 cyl). It runs great except when I start in the normal drive position it will not shift out of first. However, I can shift it manually into second and or start out in second. I drove it home (6 hrs) and it ran fine at 65-70 miles/hour. Do I have a bad tranny or just some adjustments that might need to be made?
Thanks for the advice.
Old Sep 14, 2006 | 12:17 AM
Twister's Avatar
Twister
Default RE: 66' cruise o matic question
ok, the normal dot that you think is "drive" is second only...from the top down...Park, Reverse, Neutral, 2nd, Drive, 1st
Old Sep 14, 2006 | 12:38 AM
jsalomone's Avatar
jsalomone
Thanks for the response:
So if I use the green dot I should not have to move it correct? If I use the green dot it will not shift out of first, however I can manually shift it into second or the small dot.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
UrS4
Oct 3, 2015 06:23 AM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
UrS4
Sep 30, 2015 10:13 AM
treesloth
Sep 28, 2015 07:03 AM
