keyless entry
Old Sep 14, 2006 | 04:18 AM
roblarss's Avatar
roblarss
Default keyless entry
Does anyone know if the 94 gt's had keyless entry at that time? My door locks are getting pretty rough and I remember some cars having that at that time. (didnt get any remote or anything with car and only got one really worn out key).
Old Sep 18, 2006 | 07:26 PM
ret27m's Avatar
ret27m
Default RE: keyless entry
Yes the 94 GT had keyless entry, remotes are available thru ebay. If you need to know how to program one (a remote) here is how its done.
How to Program a 1994 Mustang GT Ford Remote
To program (or reprogram) keyless entry remote transmitter into the remote
keyless entry module, perform the following steps:
1. Turn ignition switch to RUN or ACC position and momentarily short the
two terminals of the Program Connector (two-pin connector next to the remote
keyless entry module. Remove LH luggage compartment trim panel (Trunk Area) to reach the
connector). Both doors should lock and then unlock. Remove shorting pin.
2. Press any button on keyless entry remote transmitter. All front doors
should lock and then unlock to verify that keyless entry remote transmitter has
been programmed.
3. If door locks do not respond, press button again (up to three times
maximum with the same keyless entry remote transmitter).
4. Repeat Step 2 to program additional keyless entry remote transmitters (up to 4 remotes)
into the remote keyless entry module (up to a maximum of four keyless entry
remote transmitters).
5. Turn ignition switch OFF. Both doors should lock and then unlock.
6. Check operation.
The above is for the 94-98 Ford Mustang, other years should be the same.
Old Sep 18, 2006 | 10:37 PM
FutBall23's Avatar
FutBall23
+1^^^^^^^^^^
dubarado
Dec 23, 2015 01:16 PM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
Sep 8, 2015 11:50 AM
ccwebb
Aug 11, 2015 06:47 PM
