speedo/odo not responding
Old Jul 10, 2004 | 02:16 PM
lane's Avatar
lane
Default speedo/odo not responding
Well, I recently had my speedometer and odometer, including the trip meter, stop responding. I read on another forum that someone was able to get it working temporarily by hitting the trip reset switch. Same thing here.
I reset the trip, and drove around a couple blocks. The speedometer read ~20mph, and the trip meter was rolling. When I got back to the main street, the speedometer fell back down to 0 at ~40mph, and the trip meter stopped too.
Anyone have any ideas about a cause and/or solution to this problem?
As an added note, I've also been having tach accuracy issues. Sometimes it goes along with the engine, and other times if i'm accellerating hard, the needle flies up from like 2k to 5k faster than it would if i floored it in neutral. At one point, the needle even went up and fell to a resting state all the way past the redline as if it were pegged.
Punching the console sometimes fixes the issue, and puts it back to normal, but I'd rather have a real solution to this problem.
Old Jul 10, 2004 | 05:26 PM
NOS/MAN's Avatar
NOS/MAN
I ♥ Acer
Default RE: speedo/odo not responding
what year you got cable or electrical..,,,,,
Old Jul 10, 2004 | 05:27 PM
lane's Avatar
lane
oops, my bad... got a 1995 5spd V6
Old Jul 10, 2004 | 09:44 PM
NOS/MAN's Avatar
NOS/MAN
I ♥ Acer
ORIGINAL: lane
humm im not really sure on that year..look under car and see what it has if elect..might just be a fuse..if cable maybe cable broken..
Old Jul 10, 2004 | 10:31 PM
lane's Avatar
lane
i think it's got a cable
Old Jul 11, 2004 | 01:40 AM
NOS/MAN's Avatar
NOS/MAN
I ♥ Acer
TAKE TO LOOSE FROM THE TRANS ,,TURN IT SEE IF IT WORKS??
Old Jul 11, 2004 | 11:04 PM
lane's Avatar
lane
i haven't checked that yet, but the car's got 120k+ on it... think the cable needs a-changing? and is there anything special about replacing it?
Old Jul 13, 2004 | 10:47 PM
lane's Avatar
lane
do i need to use special speedo cable grease?
Old Jul 15, 2004 | 06:07 PM
NOS/MAN's Avatar
NOS/MAN
I ♥ Acer
no ..just change the cable not that exp.. might have come undone at back off speedo head if it wasnt cliped in good..might want to check that first ,,not an easy feel...hard to get to..
Old Jul 17, 2004 | 02:08 PM
lane's Avatar
lane
well, i haven't gotten a chance to take the dash apart and look at the cluster yet, but i did take a look at the underside, and is this the speedo conenction from the tranny, behind the O2 sensor conenction?
[IMG]local://upfiles/7908/FF760ECEACCA4CBB8B634725D54FEFE6.jpg[/IMG]
[IMG]local://upfiles/7908/5179EA0424EF425DB20BE95248B3737F.jpg[/IMG]
