Changing Turn Light Bulb
Old Sep 19, 2006 | 08:15 PM
picsaro's Avatar
picsaro
Default Changing Turn Light Bulb
This is probably a dumb question, but im new to car maintenance.
I have a 2000 V6. My rear turn light is out. The manual says take the car to a dealer to have them changed. When I look in the trunk, I dont see how I can get to it. Does anyone know of a link to instructions so i can do it myself?
thanks
Old Sep 19, 2006 | 08:54 PM
DG03's Avatar
DG03
Default RE: Changing Turn Light Bulb
Remove the plastic retainers that hold in your cargo net
Pull back carpet
Remove 4 11mm nuts from tail light
Pull light out
Change bulb
Reverse the procedure to install.
Old Sep 19, 2006 | 09:19 PM
picsaro's Avatar
picsaro
but its all welded together. i cant remove the metal piece behind the carpeting
Old Sep 19, 2006 | 09:53 PM
DG03's Avatar
DG03
Look for the 4 nuts, loosen them.
Old Sep 19, 2006 | 10:12 PM
72MachOne99GT's Avatar
72MachOne99GT
2010 Blue Ball Award Recipient
Ive had one out for 2 years
Still havent replaced it, nor my foglights..
am i lazy?
Old Sep 19, 2006 | 10:25 PM
Raven_pbr's Avatar
Raven_pbr
No you aren't lazy. Its a pain in the butt gettin the carpet out and gettin the bolts out.
Old Sep 19, 2006 | 10:44 PM
72MachOne99GT
not to thread'jack' but is there anywhere that carries either of the lights im missing
ive looked everytime i go to a new store for the foglights for our GT's and nobody and i mean NOBODY carries them
and ive never seen the taillights either..
kind of bothersome to be honest[>:]
Old Sep 20, 2006 | 12:43 AM
Raven_pbr's Avatar
Raven_pbr
I'm suprised that you can't get the tail lights from a store. They SHOULD have those.. the fog lights you could probably get from Ford, or online.. if the store can't order them for you.
Old Sep 20, 2006 | 12:55 AM
amrcnidyot's Avatar
amrcnidyot
i got replacement tail ligts from autozone. i think they even had em at walmart. the tails are really eazy to take off and its not really a pain. you take off the plastic cover around the trunk latch then remove the 2 plastic screw on pins that hold the rear carpet thing on then take that out then you can just kinda bend the carpet on the side of the trunk that you are working on back and you can see..dont remember...like 5 bolts. unscrew and pull ur taillight out. done it many times.
Old Sep 20, 2006 | 01:20 AM
72MachOne99GT
you guys must have real stores,, walmart, auto zone, napa, advance,, none of them around here carry either light bulb i need
by the way amrcnidyot awesome choice on the color
i think we're the only 2 of 'maybe' 3-4 members with it (that actually post i mean)
