doin burnout using e-brake
Old Jul 15, 2004 | 01:38 PM
RollinThunder's Avatar
RollinThunder
Default doin burnout using e-brake
when I go to the track can I do a burnout using the e-brake instead of the brake???
Old Jul 15, 2004 | 01:43 PM
Sidewayz6.0's Avatar
Sidewayz6.0
Default RE: doin burnout using e-brake
Wow...No. The e-brake only uses the rear brakes. You need to hold the front tires in place...
Old Jul 15, 2004 | 02:06 PM
OneGearhead's Avatar
OneGearhead
its not a Honda, so, no. just dump the clutch and heat 'em up. u dont need to sit there and powerbrake it. rev to @ 3k, dump it and just heat em up a lil bit. thats all you really need imo. if u get 'em too hot(street tires), wont hook for ****. i just spin mine thru first and i pull up. IF i even spin 'em at all. but, do wut u want
Old Jul 15, 2004 | 07:23 PM
mkspeed26's Avatar
mkspeed26
fwd cars use the e-brake to do a burnout for 1 main reason, they dont have enough torque to do it without the resistance of the non-driving wheels being locked up. brakes are baised so that the front brakes grip harder than the front brakes (usually about 70/30), so pressing the brake pedal would lock up the driving wheels more than the non-driving wheels. that would make it harder to do a burnout. by using the e-brake to lock up the rear wheels and while letting the front wheels spin without brake resistance, it is easier to get the wheels spinning.
now, for a rwd car, such as a mustang. most rwd cars have more torque, because most of them have V6s and V8s, compared to the I4s and smaller V6s in fwd cars. So they will usually get the wheels spinning without the assistance of resistance from the non-driving wheels. so, just rev it and drop it and watch the wheels spin. if you need resistance to get them spinning, slightly apply brake pedal pressure. again, since your brakes are baised, brake pressure will put more resistance on the front, or non-driving tires in this case. this will help to get the rear tires spinning.
Old Jul 15, 2004 | 11:18 PM
2001mustang's Avatar
2001mustang
What is the easiest way to do a burn out in an automatic?
Old Jul 15, 2004 | 11:24 PM
NOS/MAN's Avatar
NOS/MAN
I ♥ Acer
power brake it ...if you hand brake it you wont go nowhere,,unless you got a ft. wheel drive mustang???
Old Jul 15, 2004 | 11:27 PM
2001mustang
This is a dumb question but how do you power break.
Old Jul 16, 2004 | 12:45 AM
matthockey32's Avatar
matthockey32
I ♥ Acer
hit the brake gas at the same time.
Old Jul 16, 2004 | 01:08 AM
89vertgt's Avatar
89vertgt
power breaking in an auto 5.0 is sooooo easy....I just did it bout an hour ago...covered the road in smoke it was beautiful
Old Jul 16, 2004 | 03:25 AM
OneGearhead
its GREAT. thats the only reason id have an automatic. POWERBREAKS. haha. and the smell of burnt rubber......i LOVE IT. thats why i like goin to drag strips so much. god i am addicted to cars. oh well. gotta love something.
