Difference in speed / acceleration / sound from v6 to v8?
Old Jul 15, 2004 | 10:08 PM
ownage9's Avatar
ownage9
Default Difference in speed / acceleration / sound from v6 to v8?
How much of a difference is it? Is it possible to make a v6 act and sound like a v8 for like a couple grand? Explain please im stupid@!
Old Jul 15, 2004 | 10:19 PM
mkspeed26's Avatar
mkspeed26
Default RE: Difference in speed / acceleration / sound from v6 to v8?
ya, you can make a V6 sound, perform, whatever like a V8. or, you can just buy a V8 in the first place!!
Old Jul 15, 2004 | 10:22 PM
jdaniel's Avatar
jdaniel
I ♥ Acer
In order to make a V6 sound or perform anything like a GT you would have to sink more money in it than its worth. You would be better off buying a V8 in the first place.
Old Jul 15, 2004 | 11:12 PM
2001mustang's Avatar
2001mustang
If you want to get a good start on getting your 3.8 to perform like a GT get a Diablo Delta Chip or the Predator program. Both would be a good combination. I have the chip and it has made a big difference in performance.
Old Jul 15, 2004 | 11:24 PM
Monch's Avatar
Monch
i don't think you'd be able to get the sound of a v8, after all it's a v6, but i certainly believe you could get to GT performance with chips, exhaust, intake and pullies. not a whole lot of money, maybe $1500-$1800 ?
Old Jul 16, 2004 | 01:09 AM
matthockey32's Avatar
matthockey32
I ♥ Acer
i have spent $2000 and am almost in the 13s. and it sounds more badass than a GT.
Old Jul 16, 2004 | 01:17 AM
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
Thats a VERY impresive V6, and your NA too?
Old Jul 16, 2004 | 01:37 AM
SCARFACE's Avatar
SCARFACE
I'm a living experience... I recomend that if anyone is trying to make their v6 into a v8 your better off buying a v8 --- too much money, I did it myself - I use to have a 00 v6, my idea was to make it as fast as a v8 but when I go it to be as fast as a v8 I had put in so many mods and so much money - it sure looked like a v8, it almost sounded like one but it was not a v8 - I would race v8's all the time, when we both took off we were even, but once 3rd gear kicked they were gone - my hp on my v6 was almost as high as a v8 but in torque I was way below a GT.
I thought about it after, and came to the conclution that I can make it as fast as a GT but once I get there a reall GT can add a few mods more and that will kill everything I did to the v6 to make it a v8, can't compete.
What I end up doing was trading my v6, not for a GT, but for a Cobra - that way I was going to try to do the same, and now try to make the GT into a Cobra.
heres a pic of my 00 v6 --- looks sharp but it took alot to make it what it was, I shouldof got a GT to start, damn!!!
Old Jul 16, 2004 | 01:39 AM
SCARFACE's Avatar
SCARFACE
here the pic of me and my v6 - i don't know what looks sexier, me or the v6 LOL
[IMG]local://upfiles/5848/8D29BD836E5B4154A63CEFDBF38F0FCD.jpg[/IMG]
Old Jul 16, 2004 | 04:19 AM
SCARFACE's Avatar
SCARFACE
Default SPECS ON THE V6 (keep them in mine)
2000 Ford Mustang V6
bodywork
Type 2+2 FHC
Designer
Number of doors 2
dimensions & weights
Wheelbase 2573 mm 101.3 in
Track front 1534 mm 60.4 in
rear 1539 mm 60.6 in
Length 4653 mm 183.2 in
Width 1857 mm 73.1 in
Height 1349 mm 53.1 in
Ground clearance
Curb weight 1390 kg 3064 lb
Weight distribution(Front)
Fuel capacity 59.5litres 13.1UK Gal 15.7US Gal
aerodynamics
Drag coefficient
Frontal Area
Cx
engine
Code
Manufacturer Ford
Type S-6
OHV12 valves total2 valves per cylinder
Bore × stroke 96.52mm × 86.36mm
3.8 in × 3.4 in
Bore/Stroke ratio 1.12
Displacement 3791 cc(231.341 cu in)
Unitary capacity 631.83 cc/cylinder
Construction
Coolant Water
Main bearings
Compression ratio 9.36:1
Fuel system SMPFi
Aspiration Normal
Compressor type N/A
Intercooler None
Max. output(SAEnet) 190.0 bhp (141.7 kW)@5250 rpm
Max. torque(SAEnet) 298.0 nm (220 lbft) (30.4 kgm)@2750 rpm
Max. rpm
Specific output 50.1 bhp/litre
0.82 bhp/cu in
Specific torque 78.61 nm/litre
performance
Note: A value of -1 means that the car cannot attain that speed.
0-50mph (80 km/h)
