Supercharging question
Old Jul 18, 2004 | 09:13 PM
callmecobra's Avatar
callmecobra
Default RE: Supercharging question
ORIGINAL: fast83gt
What's not true about it?
what you said about 15psi from a turbo vs 6psi from a roots. the turbo at 6psi would be pushing alot more air than a equal sized roots blower at 6psi. roots blowers are around 55% efficient, while turbos are near 90%. and what you said about centrifugal/turbos not compressing air in the cylinders and doing it in themselves? huh??? that makes no sense dude
Old Jul 18, 2004 | 09:17 PM
fast83gt's Avatar
fast83gt
This is a quote from Holley's website:
The Roots blower is the simplest of all blowers and therefore is also the least expensive. A Roots blower does not compress the air inside the supercharger. It is actually an air pump. The compression of the inlet charge (creation of boost) actually takes place in the cylinders and the manifold.
Centrifugal superchargers and screw type superchargers are called "internal compression" blowers because the air compression takes place inside the supercharger. Roots superchargers are "external compression" blowers because the air compression takes place outside of the supercharger.
Old Jul 18, 2004 | 09:19 PM
fast83gt's Avatar
fast83gt
Holley has some great info on their site follow this link:
http://www.holley.com/HiOctn/TechSer...fo/SCTech.html
I was a little off when I saidv "8.1:1 compression ratio is like running a 12.1:1"
it's actually 8.5:1 and 12.0:1
Old Jul 18, 2004 | 09:25 PM
callmecobra
ORIGINAL: fast83gt
i wasnt debating about that man...i was under the impression that you thought centrifugals dont compress air in the cylinders....thus making them pointless[&:] but still, i would like to learn more about this internal compression thing. it makes no sense at all. a centrifugal uses an impellar to suck air in, and push it out. if you took the intake pipe off of it, and blew it into the atmosphere, the air wouldnt be compressed, like holley says it is. it would be no different than the fan on your ceiling.
Old Jul 18, 2004 | 09:41 PM
fast83gt's Avatar
fast83gt
this site explains it fairly well
http://www.superchargersonline.com/content.asp?id=21
Old Jul 18, 2004 | 09:55 PM
callmecobra
"the centrifugal supercharger essentially acts as a high-speed fan"
i dont see any compression going on inside that diagram. theres something im not getting here. ill try to figure it out when i sober up[&:]
Old Jul 20, 2004 | 06:43 AM
92BOOSTED's Avatar
92BOOSTED
Think about it this way.
Blow into a straw(the straw being the pipe after the centrifical unit)and then put your finger at the end of the straw(acting as the throttle body) while your still blowing into it,what happens?
It has pressure built,then remove your finger and it flows.
That is why there is a bypass valve before the throttle body so when you let off the pedal,it keeps the whole system from surging.Besides,boost in terms of cfm is good.Boost in terms of backpressure is bad as it just means that there is a bottleneck somewhere else(restriction of flow).You are just trying to make the system as efficient as possible.That is why you see boost pressure.
Rye
Old Jul 20, 2004 | 03:51 PM
callmecobra
ORIGINAL: 92BOOSTED
Rye
i 100% understand boost 92. and your correct, cfm's is what matters, not boost at all. most people dont know that. the trouble i was having was trying to figure out how a centrifutgal is an internal compressor, but i get it now
Old Jul 20, 2004 | 08:04 PM
92BOOSTED's Avatar
92BOOSTED
That was the best i could come up with.I hope it helps.
Rye
PS Hey nomo,you have quite a lot of posts.good job
Old Jul 20, 2004 | 08:36 PM
callmecobra
ORIGINAL: 92BOOSTED
haha, is that sarcastic?
chrisdbassplayer
Oct 13, 2015 06:53 PM
treesloth
Sep 28, 2015 07:03 AM
col2560
Sep 25, 2015 08:59 PM
