traction locks???
Old Sep 25, 2006 | 02:35 AM
tuneskies's Avatar
tuneskies
Default traction locks???
I cant burn out off the line out of drive, but i can power brake and leave 2 tracks. Someone told me that I might need a traction lock rebuild. Could that be the case? I just recently got the car and I am pretty sure i should be able to squeel them without a problem. Any pointers? It seems to me that the traction locks are fine since both wheels spin...
Old Sep 25, 2006 | 02:42 AM
Colorado_Mustang's Avatar
Colorado_Mustang
Default RE: traction locks???
Two black stripes equals good limited slip.
There is also a spec to check the torque required to turn one wheel with one wheel off the ground.
Not being able to spin the tires off the line has more to do with the available traction, engine power, and tranny setup.
Old Sep 25, 2006 | 03:32 AM
amrcnidyot's Avatar
amrcnidyot
ORIGINAL: Colorado_Mustang
thats a big one. i had a 95 camaro v6 with ok tires and if i punched it at a stand still in drive i could spin the tires for just about as long as i wanted but with the stang...more power different trany and about the same quality tires i cant even get close to doin that.
Old Sep 25, 2006 | 09:58 AM
7upedition's Avatar
7upedition
chances are with the 8.8 trak lok rearemd, you'll need to replace the trak lok clutches, they are available at summit or jegs, be sure to soak the clutch discs in rear diff fliud for a few days prior to installing them. you'll need 3 qts or rear diff fluid also.
Old Sep 25, 2006 | 10:08 AM
P Zero's Avatar
P Zero
If you cant spin em from a dead stop without brake torquing thats more with your engine output rather than your limited slip. If your limited slip was broken or not working it would be a single spinner and only leave 1 patch. Im going to assume you have an auto, the AOD is not very burnout friendly. I have one in my truck and even with 3.73 gears, it doesnt wanna break em loose. You might wanna consider a stall torque convertor, itll make it a lot easier to break the tires loose.
-P.
BOB ROME
Jul 26, 2023 01:54 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
guitarman376
Sep 30, 2015 05:54 PM
logan409
Sep 26, 2015 07:43 PM
Sep 25, 2015 06:58 PM
