HELP!!!!!!!!!!!!!!!!!
Old Sep 29, 2006 | 12:04 AM
1998GT's Avatar
1998GT
Default HELP!!!!!!!!!!!!!!!!!
what happens if i mess up the firing order??
Old Sep 29, 2006 | 12:43 AM
OnyxCobra's Avatar
OnyxCobra
Default RE: HELP!!!!!!!!!!!!!!!!!
it'll run very ****ty
Old Sep 29, 2006 | 01:17 AM
Poobs's Avatar
Poobs
Never seen it in a modern motor onlt ones with distributors and carb.
On a motor with didtributor and a carburato it can cause all kinds of popping, firing thru the carburetor, farting and snorting. Also mis firing, running backwards , you name it
Old Sep 29, 2006 | 01:26 AM
FoxGT's Avatar
FoxGT
You won't be able to do a burnout or slide corners well. My friends mustang was wired wrong & he came to me asking what the problem was. I looked &... I found the mistake, it wasn't a bad mistake, but one none the less. He had the non H.O. firing order in mind when wiring it. I rewired it. Then he went & layed some rubber in front of his house. (for the first time)
Old Sep 29, 2006 | 12:22 PM
Deannostang's Avatar
Deannostang
You will eventually (sooner rather than later) frog up your engine. NOT A GOOD THING!
Old Sep 30, 2006 | 11:02 AM
CobraBob's Avatar
CobraBob
Just curious why you asked. Is your motor running badly?
