Dyno numbers(Whats yours?)
I'm just wondering what some people are getting with what mods!!
It should be a good post.
Rye
I had 370hp and 360tq at the wheels before the recent changes that you see below.
Rye
i've got 1.8 roller rockers, Pro-M mass air, MAC CAI, 70mm TB, port matched intake manifold, custom diablo chip, custom 3.5 inch exhaust, royal purple oil in engine, tranny, and rearend. last dyno run was 231.9 @ 5800 RPM and 241.3 ib-ft of trq @ 2600 rpm.
i was doing 460rwhp in the 96 cobra, with bolt ons....8psi s trim with aftercooler, water injection, long tubes, off road h, weld in flowmasters[:@], msd dis 4 with wires, powerpipe, amsoil everything.
And I got the least power here.
Wont be that bad after this winter tho
This was before the nitrous, and well just before the nitrous.
heres what I got for mods so far.
Current mods:
[ul][*] 4.10 Gears[*] Ford B303 Cam:
. Duration': 224°/224° @ .050'
. Lift: .480'/.480' [*] Steeda Aluminum Underdrive Pulleys[*] Edelbrock Performer Intake(1500-6500)[*] 24# Injectors[*] N.O.S. 75 Dry Shot[*] Pro-M Bullet 75mm MAF for 24# Injectors[*] Accufab 70mm TB[*] Edelbrock 70mm EGR Spacer[*] Chrome Breather Valve[*] BBK Fenderwell CAI[*] BBK 1 3/4" Ceramic Coated Long Tube Headers[*] BBK 2.5" Off Road Shorty X Pipe[*] Flowmaster 40 Series Mufflers[*] Eibach Pro-kit Springs - Lowered 1.5"[*] Steeda Tri-Ax Short Throw Shifter[*] MSD Pro-Billet Distributor[*] AC Delete Kit[*] Smog Removed[*] Powerslot Rotors w/ Hawk Performance Pads
[/ul]
Along with Stock as Stock can be heads.
Current mods:
[/ul]
pro charger is off now,[
], got to rebuild motor soon,,,going to get piston and rod and ring package,,got to take heads of to see if motor needs to be bored probly not..i can just hone it out install new rod and pistons,,,pro power got a deal going right now ,,the whole kit is $799.99 no crank i dont need a crank because i got a cobra,,allrerady got one...........the flat tops will give me 10.5 to 1 compression ,,,,dished 8.5 to 1 ,,may get rid of the charger???
ORIGINAL: matthockey32
Where did you get those roller rockers from for that 2002?
ORIGINAL: nhdungeonracer
My #'s are below...(lowest here so far [
Mods are also listed below (not many....yet
])Mods are also listed below (not many....yet
Much lighter than mine with a Hatch AND ground effects...
But yours SUCKS SO BAD in turns
