What shifters are u guys using?
Old Jul 28, 2004 | 11:47 PM
cobravenom302's Avatar
cobravenom302
Default What shifters are u guys using?
I put a pro 5.0 shifter in my 95 GT last week and now, im getting alot of vibrations and noise from the shifter. i pulled the boot off and drove it to see if i could see anything but it looked fine, it has a 30 day return on it so i was wondering what type of shifters u guys have, and how you like them. Any Pro 5.0 owners out there that have noticed this problem? I mean i love this shifter its night and day compaired to the stock crap.
[IMG]local://upfiles/8185/EE4718FCBBE447A28AFC5F56966B23CB.jpg[/IMG]
Old Jul 29, 2004 | 12:05 AM
jdaniel's Avatar
jdaniel
I ♥ Acer
Default RE: What shifters are u guys using?
I have a Pro 5.0 and I LOVE it. Wouldnt change it for the world. But I dont get any noises out of it though.
Old Jul 29, 2004 | 12:25 AM
95Stealth302's Avatar
95Stealth302
I got me a Pro 5.0 shifter and love it in my 95 GT. I'd say check the U joints and such but otherwise I've driven with the Steeda Tri Ax in my buddies car and don't like it as much, just different shift angles and stuff.
Old Jul 29, 2004 | 12:28 AM
RollinThunder's Avatar
RollinThunder
I have the steeda tri-ax and actually thinking about puttin the pro 5.0 in it..I dont really like the 2'd to 3'd shift in the steeda
Old Jul 29, 2004 | 12:32 AM
RollinThunder
ORIGINAL: jdaniel
JD hows the 2-3 shift in ur pro 5.0 does it slide into the slots better then the steeda..can u miss third?
Old Jul 29, 2004 | 12:36 AM
cobravenom302
doesnt the steeda have that spring loaded feature for 2nd- 3rd thats suppose to be the best? atleast that what steeda says
Old Jul 29, 2004 | 12:38 AM
cobravenom302
2nd-3rd on the 5.0 is awesome it goes right in! each shift is solid
Old Jul 29, 2004 | 12:48 AM
Obsol3te's Avatar
Obsol3te
The vibration is occuring because the stock shifter had a rubber boot in between the upper and lower arm of the shifter itself.
Now it's just a metal to metal contact, so it Will make noises.
Tho mine doesnt unless you put your ear to the thing, I hear its very common because of it.
And I'll be the first to stick up for the Tri-Ax
Yes it has that spring from 2nd to third you just have to push up and slides right in.
Tri-Ax is de Best!
Old Jul 29, 2004 | 12:55 AM
T_stang's Avatar
T_stang
Wow i still use my hurst short throw and ive never had no problems with it
Old Jul 29, 2004 | 01:00 AM
RollinThunder
ORIGINAL: Obsol3te
Tri-Ax is de Best!
then how come I always and I mean always screw up that shift..I could nail that shift perfectly w/ me stock shifter..but the tri-ax is givin me alot of headaches...fill me in
