ignition system
Old Oct 18, 2006 | 11:27 AM
2003gtron's Avatar
2003gtron
Default ignition system
Hey guys. How do I know that all eight spark plugs are igniting and not just seven?
Is there such a test?
So, if I took my car to a garage, how would those guys go about finding out?
thanks,
ronnie
2003 GT
nuthin' special-CAI, xpipes, suspension stuff
Old Oct 18, 2006 | 03:36 PM
5IVE.OH's Avatar
5IVE.OH
Default RE: ignition system
Yeah they'll hook it up and tell you if it's got a miss.
Old Oct 18, 2006 | 05:20 PM
Archion's Avatar
Archion
One way I did it in my shop, worked esp well on headers, I had an infared thermometer would point it to the exhaust ports and see which one is colder. Another way is to use a good set of wire pullers and pull and replac the wires in succession untill it does not make a diff and there is youre problem
Old Oct 19, 2006 | 03:28 AM
kckeener's Avatar
kckeener
You can get a tester cheap from harbor freighy that hooks inline. it is clear and you can SEE the spark jumping-or not, in your case! It will not find a bad plug, but everything befor it. Good luck, misses suck sometimes.
Old Oct 19, 2006 | 10:06 PM
Colorado_Mustang's Avatar
Colorado_Mustang
Well, since you don't have wires, they'll just look at the plugs, or disconnect the coil packs one at a time. Looking at a plug is probably the easiest way. A misfiring plug will be black.
mrtrodonet
Sep 19, 2020 03:12 PM
bradleyb
Nov 27, 2015 07:50 PM
breaking
Oct 2, 2015 01:27 PM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
