power window problem
Old Aug 5, 2004 | 01:51 AM
poorboys's Avatar
poorboys
Default power window problem
Hi i'm a newbie to this site and need some help-my daughters 2000vert drivers side window won't move-I checked elec. conn. and there seems to be power to all the switch conn. but only makes a slight click that can be heard in the motor itself. I guess I'm going to buy a used motor and re-place it-here is my question-How do I get it out? I can see the two most obvious screws but when I take them out nothing else moves-there are no pics in the Haynes manual-is there another place on the net where I can look-thanks
Old Aug 5, 2004 | 01:53 AM
jdaniel's Avatar
jdaniel
I ♥ Acer
Default RE: power window problem
There is probably a gear the is seamed with a sprocket that you will have to seperate. Sometimes those can be hard to pull apart. I had to do one in my dads truck and it was a pain also.
Old Aug 5, 2004 | 03:30 PM
poorboys's Avatar
poorboys
hi jdaniel-thanks I'll give it a try
Old Aug 6, 2004 | 12:13 PM
roundman's Avatar
roundman
the weight of the window may be pressing down on the small gear on the motor so support the window with one hand and push up on it a little while twisting the motor loose and see if this get it off OK.
NorthAmericanTuning
Nov 9, 2016 11:45 AM
NorthAmericanTuning
Mar 18, 2016 11:21 AM
JonnyBlazeGT
Nov 3, 2015 01:10 AM
movielover40
Aug 27, 2015 10:13 PM
HorsePower99
Aug 26, 2015 11:29 PM
