problems
Old Nov 1, 2006 | 11:04 AM
burn rubber's Avatar
burn rubber
Default problems
how do i know when the clutch ic bad? or transmission? i just bought a '91 mustang gt. the car starts but the clutch makes a poping noise when i engage it.
Old Nov 1, 2006 | 06:37 PM
Chopper's Avatar
Chopper
Default RE: problems
This could be a broken transmission or motor mount.It doesn't have to be but it could.
Old Nov 1, 2006 | 11:30 PM
BigBen09's Avatar
BigBen09
could be the throw out barring in the clutch
Old Nov 2, 2006 | 09:40 AM
corvetteguy's Avatar
corvetteguy
When the clutch is getting worn out the disc becomes
less thick, like worn out brake pads.
The pressure plate has a spring driven
plate that applies pressure to the disc.
When disc is worn the springs no longer
apply enough force and the transmission
slips.
From a stop, geer in 3rd, let out clutch and if rpm
goes up and car is not going I'd suspect clutch.
Sometimes when disc is worn enough the bearing that
depresses the pressure plate springs may travel a
lot further than normal and pop and bang from the
long travel.
I would look into adjusting the throw of the bearing
and see if it helps.
Old Nov 2, 2006 | 02:29 PM
rez_rocket's Avatar
rez_rocket
this might not help but when my tranny took a dump i could start the car and hold the clutch pedal down and nothing seamed wrong until i let the clutch out then i could hear the metal bouncing around in my tranny.
Seanam
Oct 4, 2015 10:15 AM
69Volunteer
Sep 30, 2015 10:39 AM
marc954
Sep 29, 2015 03:05 PM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
