buzz on and off vibration
Old Nov 3, 2006 | 04:20 PM
hawkj's Avatar
hawkj
Default buzz on and off vibration
I have 1984 5.0 GT mustang has been running fine untill a few days ago I get this vibration at 45-55 Mph.had drive shaft checked had bad front u-joint replaced both of them yet vibration is still there when I jack up the car and run it in gear to that speed vibration is there,I marked the flange and pinion flange to make sure I put it back right and not 180 out.my trans yoke (automatic) has a dampner ring does not look damaged .you guys got any suggestions.The vibration goes Hmmm-hmmmm-hmmmm and can feel it through the foor and dash buzzes.Thanks
Old Nov 3, 2006 | 04:57 PM
frg_eyz's Avatar
frg_eyz
Default RE: buzz on and off vibration
If you go faster does it stop?
Old Nov 3, 2006 | 05:08 PM
ponysnake99's Avatar
ponysnake99
does your steering wheel vibrate too? it may be your tires are out of balance...but if it is, it is a distinctly mechanical sound?
Old Nov 3, 2006 | 06:56 PM
GreyStang's Avatar
GreyStang
Maybe the car tossed a wheel weight?
Old Nov 4, 2006 | 05:05 PM
hawkj's Avatar
hawkj
Yes it stops at about 60 did not take it any faster though. this is not a wheel out of balance .
mtgldr
Feb 3, 2024 09:00 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
baddog671
Jul 26, 2016 01:20 PM
SSG Steggy
3.7L V6 Technical Discussions
Nov 5, 2015 03:09 PM
mdj89
Sep 23, 2015 08:49 AM
