Tri-Ax question...
Old Aug 10, 2004 | 07:20 PM
kingsnake's Avatar
kingsnake
Default Tri-Ax question...
Ok, at the risk of this sounding like a total noob question here it goes. I just installed my steede tri-ax shifter. It makes a rather loud clicking noise when switching gears. I just want to know if this is normal, or if it is something I should be concerned about. I'm assuming that it is normal with the new shifter, but I just don't want to take any chances at messing up my trans.
Thanks
Old Aug 10, 2004 | 08:32 PM
bull8t's Avatar
bull8t
Default RE: Tri-Ax question...
hmmmm, not sure if the tri-ax has stop bolts....md where you at?
Old Aug 10, 2004 | 08:35 PM
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
right hither
yea the triax has stop bolts, make sure their set properly. the tranny has internal stops as well so its better to have them too loose than too tight
Old Aug 10, 2004 | 09:02 PM
kingsnake's Avatar
kingsnake
I set the stop bolts exactly as the directions said, with just a slight air gap between the lever and the bolt when pressure is applied to the lever.
Old Aug 10, 2004 | 09:23 PM
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
then your good to go, mines real notchy too - I like it teh notchy
Old Aug 10, 2004 | 10:04 PM
kingsnake's Avatar
kingsnake
Thanks. I just wanted to make sure it was normal.
Old Aug 10, 2004 | 10:09 PM
jdaniel's Avatar
jdaniel
I ♥ Acer
I have the Pro 5.0 and I can hear mine hitting the adjustment screws also. I kinda like the sound myself.
Old Aug 10, 2004 | 10:22 PM
Obsol3te's Avatar
Obsol3te
Yeah, but the Tri-Ax is Five Bajillion times better than the Pro 5.0
Old Aug 10, 2004 | 10:25 PM
vfast's Avatar
vfast
I ♥ Acer
yeah it works great for you granny shifting guys*L*
Old Aug 10, 2004 | 11:35 PM
Obsol3te's Avatar
Obsol3te
I can't shift too fast.
But hopefully will when i get my adjustable clutch cable and clutch crap in
