Squeeky belts
Old Nov 4, 2006 | 11:30 PM
dobry's Avatar
dobry
Default Squeeky belts
anybody has any method of getting rid of squeeks coming from rubber belts such as the timing belt? it is really annoying when cold start the engine. what liquid to use or whatever works. thanks !
Old Nov 5, 2006 | 12:51 AM
sprostang's Avatar
sprostang
I ♥ Acer
Default RE: Squeeky belts
You mean the serpentine belt. You may be due for a new belt. I know people that have had belts squeek and they sprayed them with some silicone spray and that got rid of the squeek for a while.
Old Nov 5, 2006 | 11:39 AM
TwotoneVert's Avatar
TwotoneVert
Ahhh, dont use silicone, thats a lubricant, use belt dressing to get you by, its like 3 bucks a can.
Old Nov 5, 2006 | 12:23 PM
samseed101's Avatar
samseed101
COme on guys, tell him the old-school method I usually take a bar of soap and hold it under the belt. Hold it just firm enough so that the belt will grove the soap. And there you go... no more squeaks
Old Nov 5, 2006 | 01:22 PM
dobry's Avatar
dobry
thanks guys
Old Nov 5, 2006 | 03:24 PM
SXGT's Avatar
SXGT
Hmm, what about wd 40 [&:][&:][&:][&:] sorry iam poor and trapped at shool
Old Nov 5, 2006 | 03:48 PM
65coupe88hatch's Avatar
65coupe88hatch
really the sprays dont do alot for the belt but soften it and make it stop squeeking for short periods until it drys out again, mine has a little squeel when its a cold start i learned to ignor it since it goes away once it hits normal temp.
Old Nov 5, 2006 | 04:07 PM
Sparks232's Avatar
Sparks232
Does that soap thing really work?? and on another note my buddy put anti squeel stuff on his belt and it made his engine whine a little bit...kind of the same noise as a supercharger...just not nearly as loud.
Old Nov 20, 2006 | 11:01 PM
dobry's Avatar
dobry
i dont know about the soap, but i used grease called krytox(for bushings) and it works fine! recommended
Old Nov 21, 2006 | 03:51 AM
onegreedy's Avatar
onegreedy
bad pulley if sounds like that
