help with check engine light
Old Nov 13, 2006 | 12:29 PM
onegreedy's Avatar
onegreedy
Default help with check engine light
i have 3 cel codes here, they were on since the car has been running after the swap
#1 p1151 says lack of h02s21 swt lean (i am pretty sure this is just o2 sensor and will replace it this weekend)
this next code is whats throwing me off
#2 p0443 evap ctrl cir error
i have no clue why this is coming up, i was thinking about getting all the evap stuff turned off, do you think thats an option? would it affect my fuel milage dramatically?
#3 p0171 sys lean(i am guessing this is becuse of o2?) could even be the 80 mm maf
ANYIDEAS ON #2
Old Nov 13, 2006 | 01:29 PM
shifterdelux's Avatar
shifterdelux
Default RE: help with check engine light
You are lean because you stuck a new MAF in and didnt recalibrated your MAF transfer table. (Im assuming)
That is why you are getting all these 3 codes. It is possible that O2 is good, otherwise how else would it know you are lean. Evaparative system is related to you being lean.
Old Nov 13, 2006 | 02:37 PM
onegreedy's Avatar
onegreedy
ORIGINAL: shifterdelux
dude get a brain, the maf is not going to make no signal from the o2 sensor, yes it will make it run lean but , code 1 and 2 were on since the swap, 2 months, maf went on this weekend
Old Nov 13, 2006 | 02:45 PM
shifterdelux
Hey, you didnt mention codes before and after MAF went on.
Now, I deal with aftermarket engine controllers on a daily, we install them, we race them, we even build them our selves. I gave you a solid answer the way you described it. I dont know where you from, but where I from we dont get rude, especially with people that are trying to help you out. Etiquette and protocol are not optional, and just because your mother failed you as child, is no reason why I and other members of this site should suffer to your ignorance.
Old Nov 13, 2006 | 02:52 PM
ponysnake99's Avatar
ponysnake99
you may have misconnected some of the evap hoses durin the swap, also make sure the solinoid is workin right too...doublecheck everything
Old Nov 13, 2006 | 05:37 PM
onegreedy's Avatar
onegreedy
well atleast i dont go around talking a buch of smack and then going and deleting or editing the posts, seriosuly if you know anything about cars you should know the maf sensor yes can cause a car to run rich or lean but it cannot cause an o2 sensor to act like it is unplugged, i am sorry if i have little patience for people that give advice that does not make sense
and for aftermarket engine controllers, i am curious as to what you build? install and race(with your expired license)
my main question was regarding the #2 code like i said see below
**********ANYIDEAS ON #2*******
i guess i was not clear on my question
Old Nov 13, 2006 | 05:40 PM
onegreedy's Avatar
onegreedy
ya i am gonna try to test the solonoid this weekend, also i will check the connector and the hose connections
thanks
djbigskrilla
Sep 20, 2022 01:04 AM
labudski
Aug 24, 2015 07:23 AM
microgt
Aug 20, 2015 07:12 AM
mweiland
Aug 13, 2015 05:11 PM
drumhedd2005
Aug 13, 2015 09:59 AM
