mystery engine problem???
Old Nov 18, 2006 | 09:58 PM
tuneskies's Avatar
tuneskies
Default mystery engine problem???
My engine feels like its misfiring, but i have ran a diagnostics even and nothing is coming up. I sometimes stalls after i start it cold from sitting for a few days. I can feel it almost like it is misfiring when i put it into drive and sit there. Timing is good. I brought up the idea of maybe the TPS but i was told the problem would be more frequent. HELP ME WHAT IS WRONG?!?!?!?!?!?!?!
Old Nov 18, 2006 | 10:01 PM
Colorado_Mustang's Avatar
Colorado_Mustang
Default RE: mystery engine problem???
IAC, spark plugs, or wires.
Old Nov 19, 2006 | 12:56 PM
Chopper's Avatar
Chopper
While it's misfiring try unplugging individual injectors to see if the miss changes.If you find one that changes less than the others this is where I'd start looking.It could be a partially clogged or dirty injector.Short trips with many start-shut down cycles cause dried gasoline to build up on the injector tips and intake valves.This causes poor atomization and poor idle until the engine warms up enough to boil the fuel soaked into the carbon/varnish deposits.
You can clean some of this off the valves and injectors by running the tank until it's down to about a quarter tank and pouring in a can of cleaner.This concentrated mixture will clean better than one can to a full tank.Drive the car for an hour or two to allow the cleaner to do it's work.
Old Nov 19, 2006 | 03:22 PM
tuneskies's Avatar
tuneskies
is there supposed to be oil in the IAC ???
Old Nov 20, 2006 | 03:24 AM
99SlvrStang's Avatar
99SlvrStang
no
djbigskrilla
Sep 20, 2022 01:04 AM
ShaneB26154
35
Mar 4, 2021 04:05 AM
KEM Motorworks
Aug 14, 2015 10:13 PM
HIS S-197
Aug 10, 2015 05:47 PM
Pain.
Aug 7, 2015 10:48 PM
