Need Timing specs on 94' GT
Old Nov 26, 2006 | 03:30 PM
jettin169's Avatar
jettin169
Default Need Timing specs on 94' GT
After reinstalling my 5.0, I'm having trouble timing the ignition timing. When running with the light, what degree should I see on the balancer marker? Right now its running at 30BTC at idle and it has a very slight studder. I'm not sure which way to adjust it. I have the distributor at optimal running at this degree.
Old Nov 26, 2006 | 05:01 PM
Chopper's Avatar
Chopper
Default RE: Need Timing specs on 94' GT
To start you unplug the SPOUT connector directly above the electrical connector to the ignition module.The timing is supposed to be 10* BTDC at idle.You can safely advance it to about +14* at idle and still run 87 octane.30* at idle is WAAAY to much.It will idle faster but when you try to drive it it will rattle like a can full of rocks.
mungodrums
Oct 7, 2015 04:01 AM
StalkerGT
Sep 25, 2015 02:41 PM
Sep 8, 2015 11:50 AM
Webster454
Sep 7, 2015 04:59 AM
