squeaky front end
Old Aug 29, 2004 | 09:01 PM
EmptyEvergreen's Avatar
EmptyEvergreen
Default squeaky front end
when i drive at a nice solid cruise speed i hear a squeak coming from the front right tire area...its not a constans squeak its more of a squeak squeak squeak as i move along, however when i apply the brake it gos away. today i puled out and checked the wheel beqrings o see if that was the issua and they were not worn at all and they were properly greased, in great condition. which makes me wonder what the problem is. the only thing i noticed out fo the rodinary when i had it aprt was that the rotor was really rough towards the the inner area which would make sense for the squeak to stop when i aplly the brake. if it helps i didnt resurface the rotor when i put pads on last time even though they could have used it . does the rotor being replaced seem like a logical fi for this problem or is it something else? thanks
Old Aug 31, 2004 | 10:55 AM
jdaniel's Avatar
jdaniel
I ♥ Acer
Default RE: squeaky front end
Maybe the shock or spring since it isnt a constant squeek. I think if it were the brakes or rotors then it would be a steadt sound. Park the car and get a couple buddies to push down on the quarter panel and see if it happens when its parked.
Old Sep 1, 2004 | 02:03 PM
vfast's Avatar
vfast
I ♥ Acer
I hope you repacked the bearing since you has them out with some syth. grease....I'd say buy some brake quiter come in a small pack for about a buck put in on the back on the pads where in makes contact bet it goes away
Old Sep 2, 2004 | 05:04 PM
blown87Gt's Avatar
blown87Gt
j is prob right your stock shocks are prob freezing up
Old Sep 3, 2004 | 03:40 AM
EmptyEvergreen
after closer inspection i noticed that the sneaky sound is coming from the rear not the front so i dont know what it could be
zsmart
Convertible Tech
Feb 29, 2016 08:33 AM
the5
Sep 19, 2015 06:13 PM
Sparks_88
Sep 8, 2015 01:06 PM
robjh22
Suspension
Sep 8, 2015 12:47 PM
