motor build
Old Dec 11, 2006 | 12:06 AM
Eighty6five0's Avatar
Eighty6five0
Default motor build
hey guys i have a dss 306 short block with 13.5 cc dish pistons with 8.5 compression? whats stock? i wanna run twin turbos with this motor but im trying to find a cam and heads that would make this car run good and fast until i put turbos on i will be using the bbk ssi intake. i have a e cam but i heard thats called a detonation cam if any of u guys have suggestions please let me know or any of u have what not to do would be great
Old Dec 11, 2006 | 02:45 AM
Colorado_Mustang's Avatar
Colorado_Mustang
Default RE: motor build
FI Roller? Get the same cam you would for the turbo setup so you don't have to change it later. With that low compression, it won't be great with any performance oriented cam. Keep the duration up to help the pistons pull the mixture a little more into the cylinder. I wouldn't go less than 230* @ .050. 0.52x lift would be decent.
How much boost you planning on? 12-14psi or so?
firehorse02
Nov 16, 2015 11:28 AM
UrS4
Oct 3, 2015 06:23 AM
Explosive
Oct 2, 2015 07:45 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
logan409
Sep 26, 2015 07:43 PM
