Mach 460 Question
Old Dec 27, 2006 | 04:20 AM
Robby7979's Avatar
Robby7979
Default Mach 460 Question
Hey everyone,....
Im sure you are all tired of hearing questions for the mach 460 sound system...but I beg of you, please read this.
I am a new mustang owner. Got an 04 Convertable about 5 months ago. I want to install a new (aftermarket) CD player intothecar so I will have an aux. input for my mp3 player. My questions are 1)If I get a CD player that outputs higher than line level (ex. 50watt x4)....will that cause my Mach speakers to blow once it hits the factory amps? Do I need to get an outputwattage reducer for each channel? 2) Will all the speakers still work (mains, tweeters,subs) once the new unit is installed. 3) Will I have the same (or better) sound quality once the new unit is installed (I like the way the Mach'slow end sounds) or has anyone felt that the newCD player will cause forless low endin thesound, andhave to buy a sub to fill sound equal to the mach original sound? I had an Explorer that I put a new CD player in. The sound was alot cleaner...but it lost alot of low end in the process.
Thanks
Rob
Old Dec 27, 2006 | 11:48 AM
Chopper's Avatar
Chopper
Default RE: Mach 460 Question
Ford uses a proprietary sound system that doesn't work well with aftermarket parts.
You will get a lot more help if you post questions like this in the Audio section of this forum.
Old Dec 27, 2006 | 12:35 PM
GreyStang's Avatar
GreyStang
Easier to just use an FM modulator to play your music through the existing sterio rather than butcher it up
http://www.crutchfield.com/S-jF6Ko01...p;I=142FMMOD01
1BAD3V
Tennessee Regional Chapter
Oct 6, 2016 12:12 PM
PaulH2
20
Jan 31, 2016 09:48 AM
Sixer4Life
Sep 29, 2015 07:03 PM
treesloth
Sep 28, 2015 07:03 AM
1BAD3V
Indiana Regional Section
Sep 26, 2015 09:03 AM
