Wheres the fuel filter !
Old Dec 28, 2006 | 06:06 PM
chris01gt's Avatar
chris01gt
Default Wheres the fuel filter !
Just as the title says. It was easy to change in my 95 cougar, I just need to find it in the 2001 stang.
Old Dec 28, 2006 | 06:26 PM
Colorado_Mustang's Avatar
Colorado_Mustang
Default RE: Wheres the fuel filter !
Behind the diff.
Old Dec 29, 2006 | 01:18 AM
chris01gt's Avatar
chris01gt
Wheres that?....lol
Old Dec 29, 2006 | 01:45 AM
Colorado_Mustang
Rear axle. Middle.
You'll need a special tool to remove the lines from the filter. And, make sure the system isn't pressurized (let it sit over night). BTW, a face full of fuel makes things smell funny for quite some time afterward.
ORIGINAL: chris01gt
Wheres that?....lol
Old Dec 29, 2006 | 04:49 AM
petrock's Avatar
petrock
You can get the special tool to disconnect the fuel lines at any auto parts store.
To depresurize the fuel system, locate the fuel pump fuse in the fuse box (your owners manual should say where it is) and start the car. If it starts, let it run for a little bit. It will die when its sucked all the gas out. If it doesn't start, just let it crank for a little while which will also suck any fuel out of the lines. Not that hard of a job. Good luck...
Old Dec 29, 2006 | 07:03 PM
chris01gt's Avatar
chris01gt
Rear axle. Middle.
Now do I have to jack the car up to do this?
And in my old car there was a plug/ switch in the trunk under the carpet that I used, think thats where the cut off switch is here?
Old Dec 29, 2006 | 08:06 PM
petrock's Avatar
petrock
Jack the car up under the normal jack locations. You want to have the area around the axle clear for you to work, so don't jack it up via the axle. So under the frame rales should do fine. There is plenty of room under there to work with the axle out of the way.
As for the plug/switch, that is the innertia cut off switch. It kills the power to the fuel pump, but that will not depresurize the system the way you expect. Use the fuel pump fuse as I suggested before, otherwise you'll get pretty messy/smelly when you take the fuel filter off. Good luck...
Old Dec 30, 2006 | 01:19 AM
Not4you's Avatar
Not4you
try to keep the filter level once it is disconnected as you are bringing it down to the ground, it'll be full of fuel even if the system is de-pressurized. and keep the trouble light out of the way
GimpyHSHS
19
Dec 19, 2023 01:12 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
Sixx
Oct 5, 2015 07:36 PM
svfetter
Oct 5, 2015 11:39 AM
mrappe
Sep 26, 2015 10:16 AM
