engine wont start
Old Dec 29, 2006 | 01:12 AM
Probullit351s's Avatar
Probullit351s
Default engine wont start
After stalling on the highway while the car was bucking and the rpm guage was flickering... i had the puppy towed to my work. We hooked up the code reader and it said bad pickup in the distributor. So I put a new magnetic pickup in... put a new coil. And still no spark. There is power going to the coil... but i crank and crank and no success. The Icm (ignition control module) controls the coil telling it to fire. So I think it is bad. Can any body help, this stang is to good to not run.
Old Dec 29, 2006 | 01:46 AM
Colorado_Mustang's Avatar
Colorado_Mustang
Default RE: engine wont start
Control module is most likely cause. They give about that much warning before failing.
Old Dec 29, 2006 | 09:15 AM
corvetteguy's Avatar
corvetteguy
Are you sure you have gas? (hear pump hum)
Have you pulled spark plug wire to see if
there is spark?
djbigskrilla
Sep 20, 2022 01:04 AM
ShaneB26154
35
Mar 4, 2021 04:05 AM
Spiral534
Oct 6, 2015 04:31 PM
KEM Motorworks
Aug 14, 2015 10:13 PM
