carb choice
Old Jan 1, 2007 | 10:26 PM
66coupedude's Avatar
66coupedude
Default carb choice
hello. i am new here and would like to get some input on carbs. i presently have a 66 coupe with a 289 with hipo heads,a mild comp stick(not sure of the specs),full length headers,full msd igniton,and a 600 fcm edelbrock carb. i just swapped my performer intake for a performer rpm airgap intake and im thinking of changing carbs.i have a c4 automatic so i would need a carb with vacuum secondaries.i dont have alot of experince with carbs but was looking at either the edelbrock 650cfm avs or the holley 670 cfm street avenger. mainly street duty except for the occasional light to light run. more or less i am looking to squeeze everything out of this engine.it runs to good to replace. car dynoed 265hp,280ftlbs at the wheels.thanks for any help.
Old Jan 1, 2007 | 11:18 PM
Colorado_Mustang's Avatar
Colorado_Mustang
Default RE: carb choice
A 600 Holley Double Pumper would be fine. You don't need vacuum secondaries with an auto, you only need the kickdown linkage. Double Pumpers are easier to modulate and you don't have to worry about tuning the secondaries with little springs that will change with temperature.
Old Jan 1, 2007 | 11:33 PM
66coupedude
ok. as of now i dont have the kick down linkage.i run a b&m mega shifter and when its time toget gettingi just manually shift it so i might be ok without the linkage. ifi can go the route of man.secondaries is holley the only way to fly or is there other options?
Old Jan 1, 2007 | 11:40 PM
Colorado_Mustang
IMO, Holley is the best way to fly. There's also Demon carbs which are a bit more in price and looks. They are very similar, since Barry Grant basically developed the Demon instead of continuing to modify Holley's for the really picky carb people.
Old Jan 1, 2007 | 11:43 PM
66coupedude
cool.thank you for the help.
Old Jan 10, 2007 | 01:30 AM
hellas85stang's Avatar
hellas85stang
edelbrock is easiest to tune and tinker..holley is better for higher hp cars KINDA...but are tempermental..a 600dp on amild 289 isnt very efficent...a 600 maybe..
bradleyb
Nov 27, 2015 07:50 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
Daddys Girls GTs
Sep 14, 2015 08:46 PM
