mechanical fuel pressure gauge
You need an electric fuel pressure gauge. They aren't cheap, but a leak in a fuel system is a lot more expensive. You'd have to run multiple leak-prone connections to move a mech. gauge that far.
The electrical gauge is easy. The gauge should come with a sender and be complete.
The pressure range you buy will depend on what kind of system you are running. Carb'd setups only need up to 10 psi. EFI shouldn't need much more than 40-50 psi.
jaiidutch
Sep 14, 2015 10:29 AM
tramphardrocker
Sep 13, 2015 08:56 PM
