ticking noise - sometimes
Old Jan 4, 2007 | 10:10 PM
jerr3d's Avatar
jerr3d
Default ticking noise - sometimes
I have a 2002 GT with 24,000 miles, manual trans., all stock
Recently it started making a ticking noise in the engine compartment when I first start it up.
I drive 5 miles to work, and when I get there and sit and listen, it no longer is ticking. If I turn it off and then back on, no ticking.
But when I start it up in the evening the ticking is back.
thanks
Old Jan 4, 2007 | 10:37 PM
Colorado_Mustang's Avatar
Colorado_Mustang
Default RE: ticking noise - sometimes
What kind of oil you run? Have you checked how full the oil is? When was your last oil change?
Old Jan 4, 2007 | 10:41 PM
jerr3d's Avatar
jerr3d
I change the oil and filter myself every 3k miles.
I use sae 5w20 per the owners manual, and then check the level every 3 weeks or so. I checked the level a few days ago
(i est. my miles, its actually about 600 under 24k)
Old Jan 4, 2007 | 10:49 PM
Colorado_Mustang
Sounds like it could be the anti-drain back valve in the filter allowing the oil to drain from the block back to the pan.
Old Jan 4, 2007 | 11:02 PM
jerr3d's Avatar
jerr3d
O.O Wow! I will change it !! Thanks for your help Colorado_Mustang!
Old Jan 8, 2007 | 10:12 PM
jerr3d's Avatar
jerr3d
well I changed the oil filter and oil, but the noise is still there. Disappears after I drive a couple of miles.
I did notice an accumulation of what looks like yellow margarine in the top inside of the oil cap!
KingRando
Oct 2, 2015 08:06 AM
69Volunteer
Sep 30, 2015 10:39 AM
Sixer4Life
Sep 28, 2015 07:05 AM
Shadow7874
Sep 24, 2015 09:06 PM
Emblazoned
Sep 3, 2015 10:45 PM
