Sucking gas like crazy
Old Jan 6, 2007 | 12:50 PM
MustangMom's Avatar
MustangMom
Default Sucking gas like crazy
Okay, I changed engines. Same engine went in that came out, as far as size. No great modifications. For some reason, it is drinking gas like it is going out of style. Any clues?
Old Jan 6, 2007 | 07:04 PM
Chopper's Avatar
Chopper
Default RE: Sucking gas like crazy
Can't possibly tell you without knowing what kind of car,engine,and transmission combination.
It could be anything from a dirty air filter to dragging brakes.
Old Jan 6, 2007 | 10:24 PM
Sacmo's Avatar
Sacmo
Does it smell like gas around the car??? May have a leak somewhere...
Old Jan 6, 2007 | 11:06 PM
bds95stang's Avatar
bds95stang
is the check engine light on?? i had a mass airflow sensor go on me and then it rank gas like crazy cuz it wasnt geting the proper fuel to air ratio
Old Jan 7, 2007 | 12:04 AM
Lizardbreath's Avatar
Lizardbreath
Do the following. Change the Air filter/plugs/MAF and you should see an improvement in MPG.
Old Jan 7, 2007 | 12:14 AM
hammeron's Avatar
hammeron
if possible, install a locking gas cap.
Old Jan 7, 2007 | 12:22 AM
badtzmaru's Avatar
badtzmaru
How is it possible to describe a solution to a problem if you guys do not know all of the facts? what year? engine? what mods does she have? does she see any leaks? we all can speculate but c'mon! ask more questions before telling someone what do you think is wrong with their car.
Just my 2 cents.
Old Jan 7, 2007 | 01:08 PM
Sacmo's Avatar
Sacmo
I don't see anything wrong with throwing out some basic general ideas... Doesn't matter what you have, if the air filter is plugged, it's plugged... If you got a leak, it doesn't matter if it's stroked 347 or bone stock 4.8, you still got a leak...
Old Jan 7, 2007 | 07:33 PM
Pyroburner69's Avatar
Pyroburner69
all they can do right now is toss out some basics. I'm having a smilar problem but i think ill start my own topic later after i try a few things. 9mpg on a 302 with a 2b carb will not cut it
Old Jan 8, 2007 | 12:24 AM
MustangMom's Avatar
MustangMom
Sorry guys, I wasnt thinking.
4.6 out of a 2000 GT into a 2000 GT. Automatic transmission. It seems to be doing better now for some reason. I am going to keep an eye on it. Thanks for the info and I will keep that in mind should it start up again.
MustangMom
