Injectors
Old Sep 24, 2004 | 11:39 PM
94Cbra's Avatar
94Cbra
Default Injectors
Would it be a nightmare to tune 42lb/hr injectors for a daily driver?
Old Sep 24, 2004 | 11:47 PM
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
Default RE: Injectors
No, I have 42# injectors. What you plan on running 42's on?
Old Sep 25, 2004 | 12:29 AM
Obsol3te's Avatar
Obsol3te
Well, if barely anything is done to it.
It's a bad idea
Old Sep 25, 2004 | 01:14 AM
94Cbra's Avatar
94Cbra
MD, Im wanting to run a 200+shot of N20 on a 347 stroker. Im gonna order everything, get it in and just do one major mod overhaul on this thing. Just in the mist of a planning process here. Makin sure Im about to order the right stuff, I want as few hic-ups as possible when I start the buildup. Someone buy my Jeep so I can sink 10 grand in this car, damn it!
Old Sep 25, 2004 | 01:17 AM
94Cbra's Avatar
94Cbra
Im just doing the same thing with this car, that I did with my Jeep. I bought my Jeep, planned out all the mods I needed, ordered everything, got it in at the same time, and a week later my Jeep was up and running with over 4k in new parts on it. It was very fun. Was like I bought 2 cars at the same time, lol.
Old Sep 25, 2004 | 09:47 AM
vfast's Avatar
vfast
I ♥ Acer
well I would say without knowing all the spec the 24's or 30's would be all you need
Md..what ya got you need 42's?
Old Sep 25, 2004 | 10:13 AM
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
10# of boost
Old Sep 25, 2004 | 12:15 PM
vfast's Avatar
vfast
I ♥ Acer
those are just a tab big...you using an fmu to?
Old Sep 25, 2004 | 12:23 PM
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
No FMU I have a returnless fuel system. And 36#'ers would have been better right now - but I will eventually upgrade and need more fuel. 42's are alot better than they used to be for the slower pulse widths - since Ford made them for the Lightning truck with drivability in mind. As long as your over 50% duty cycle drivability will be good - as per Tim Barth @ Modular Powerhouse who tuned my car.
Car drives better than it did after the 42's and the s/c & tune then it did with the stock 19's when I was n/a. Good throttle response, no drivability problems. A slight surge at part throttle, low rpm range - I can feel it if I hold the gas steady and hold the rpm's low. Nothing to write home about though.
Old Sep 25, 2004 | 12:32 PM
vfast's Avatar
vfast
I ♥ Acer
yeah I was think 30-36 would be right for your set up..I use 42's with mine I just put a kurban reg and my fuel pressure went to hell.so I'm going back to my lil ole accel reg with no vacuum.... the ole lighten has a few more cube though..what maf you using..I really like the maf off the lightening as it's hard to peg
