Curiosity question
Old Sep 26, 2004 | 03:22 PM
94Cbra's Avatar
94Cbra
Default Curiosity question
What would be a good lopey camshaft for a S/C'ed application? Just wondering how lopey you could go with a S/C.
*I forgot to say, for a 5.0L with around 9.1 compression."
Old Sep 26, 2004 | 03:35 PM
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
Default RE: Curiosity question
Your not gonna find any lopey s/c cams unless you plan on spinnin that 5.0 way high, like 7k ish because forced induction cams generally have reduced intake duration and a wider lsa to help build build boost. You wobn't find a good street s/c cam that will lope alot
Old Sep 26, 2004 | 03:41 PM
94Cbra's Avatar
94Cbra
I know you cant have a hard lope with a S/C because if you do youll just blow your boot thru the exhaust valve. Thats why higher lobe seperation numbers are good. But Ill find somthin.
Old Sep 26, 2004 | 05:19 PM
jdaniel's Avatar
jdaniel
I ♥ Acer
MD's has a good lobe to it. Just do what he did and use NA cams but run 10psi so that way you are only actually running 7 to 8 psi. Sounds good.
Old Sep 26, 2004 | 10:35 PM
vfast's Avatar
vfast
I ♥ Acer
this cam has a real lopey sound power is great..but don't buy it for that. buy a good cam to work with your combo!
spec below on cam
Part Number: 449601 Grind Number: HR-224/339-2S-12
Engine Identification:
Start Yr. End Yr. Make Cyl Description
1985 Up FORD-MERCURY 8 FAIR IDLE, MODERATE PERFORMANCE USAGE, GOOD MID-RANGE TORQUE AND HP, MILD BRACKET RACING, AUTO TRANS W/2500+ CONVERTER, ALSO SUPERCHARGED AND/OR NITROUS, 3000-3800 CRUISE RPM, 9.0 TO 10.75 COMPRESSION RATIO ADVISED. BASIC RPM 2500-6000
Engine Size Configuration
302 C.I. V
Valve Setting: Intake .000 Exhaust .000 HOT
Lift: Intake @Cam 339 @Valve 542 All Lifts are based
on zero lash and theoretical rocker arm ratios.
Exhaust @ Cam 352 @Valve 563
Rocker Arm Ratio 1.60
Cam Timing: TAPPET @.004
Lift: Opens Closes ADV Duration
Intake 32 BTDC 74 ABDC 286 °
Exhaust 80 BBDC 34 ATDC 294 °
Spring Requirements: Triple Dual Outer Inner
Part Number 99838
Loads Closed 110 LBS @ 1.688 or 1 11/16
Open 348 LBS @ 1.148
Recommended RPM range with matching components
Minimum RPM 2500
Maximum RPM 6000
Valve Float 7000
Cam Timing: TAPPET @.050
Lift: Opens Closes Max Lift Duration
Intake 5 BTDC 39 ABDC 107 224 °
Exhaust 53 BBDC (1) BTDC 117 232 °
Remarks:
FIRING ORDER: 1-3-7-2-6-5-4-8
GimpyHSHS
19
Dec 19, 2023 01:12 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
