Holley carb help
Old Jan 11, 2007 | 06:59 AM
Torkair's Avatar
Torkair
Default Holley carb help
I am looknig into a new carb for my 351c and thus far like the holley line of carbs. However, on their disclaimer they say that their carbs should not be used on fords with an automatic. My ranchero has a 351c and a C6 auto tranny so as you can figure, this kinda puts me in a bind.
Old Jan 11, 2007 | 09:29 AM
GreyStang's Avatar
GreyStang
Default RE: Holley carb help
What?? lol A Holley carb says not to use it in an automatic Ford??!? Which model Holley are you looking at? Is this documentation online so you can post a link to it?
Maybe there's another model that Holley prefers you use instead in an automatic application?
Old Jan 11, 2007 | 05:13 PM
bds95stang's Avatar
bds95stang
ive never heard of that before, post the site where you read it.
Old Jan 11, 2007 | 05:16 PM
phil k's Avatar
phil k
i used 2 holley 450cfm carbs on my chevy tunnel ram with auto trans and itwas perfect. mylast 65 mustang had a 600cfm with auto trans (no problems).
surely this is a mistake or missunderstanding.
phil
Old Jan 11, 2007 | 09:26 PM
JD1969's Avatar
JD1969
Pro. B.S. caller outer
You probably misunderstood. I am sure what it means is that you need different carblinkage for the auto.
Old Jan 12, 2007 | 12:02 AM
Colorado_Mustang's Avatar
Colorado_Mustang
You just need to buy linkage as JD said. Holley's work great with auto's, Ford just has a separate lever on the throttle arm that controls the kickdown.
Old Jan 13, 2007 | 11:20 PM
Torkair's Avatar
Torkair
That must be what I was reading and misunderstood. So I'll just have to get the seperatekickdown mechanism. Btw the warning was on the holley page for their 750 DP 4barrels. Thanks for the help, I'm new to the world of Ford.
Old Jan 14, 2007 | 01:47 PM
kenlkorsak's Avatar
kenlkorsak
Get an Edlebrock!!!
Old Jan 14, 2007 | 02:04 PM
JD1969's Avatar
JD1969
ORIGINAL: kenlkorsak
Get an Edlebrock!!!
I really hope your joking. If you have a stockish motor and don't want to make max hp Edelbrock is fine, but for real performance Holley/Demon is the way to go.
Old Jan 14, 2007 | 02:55 PM
Colorado_Mustang
Get a Holley!!!
I think that's what you meant to say. Edelbrock[:'(]
