port and polish
Old Oct 3, 2004 | 11:42 AM
tommyboy1989's Avatar
tommyboy1989
Default port and polish
what does port and polish do? and how much does it cost?
Old Oct 3, 2004 | 11:56 AM
jdaniel's Avatar
jdaniel
I ♥ Acer
Default RE: port and polish
Well I priced out getting my heads ported and larger SS valves put in and it was gonna run me $2400. The shop said it would add in the neighborhood of 60 hp. After a P&P your engine will be able to breath better.
Old Oct 3, 2004 | 12:08 PM
vfast's Avatar
vfast
I ♥ Acer
porting and polishing can add 100 or so..it really depends on what it's on.....on a street car it would be cheaper in getting a set of alum heads with the valves you wants..machine work is high....years ago it wasn't bad as I had most of my sbc heads fitted with 2.05 valves
Old Oct 3, 2004 | 12:10 PM
tommyboy1989
how much do u think it will cost for a 2.3l?
Old Oct 3, 2004 | 12:13 PM
vfast's Avatar
vfast
I ♥ Acer
well 100.00 for valves
100 valve job
I would only match port and do some work under the bowl area and use undercut valve for more floww I would not speend the $$$ to have them polished unless the is a turbo engine
machine work 150-400
Old Oct 3, 2004 | 12:41 PM
jdaniel's Avatar
jdaniel
I ♥ Acer
didnt know this was for the 2.3. It would be a lot cheaper for that then it would to do a 4.6.
Old Oct 3, 2004 | 04:06 PM
e40water's Avatar
e40water
Well tommyboy1989 for 2.3L port and polished head and intake, You looking around under $150 if you pull the head and intake off. If you get garage to pull it, Youre gonna pay for the labour, Plus the machining of the parts and gaskets. My guess under $500 for a shop to do it.
Good Luck.
Old Oct 3, 2004 | 04:09 PM
roundman's Avatar
roundman
ORIGINAL: jdaniel
duh huh! yeah like about 1/2 as much! LOL
GimpyHSHS
19
Dec 19, 2023 01:12 PM
baddog671
Jul 26, 2016 01:20 PM
Urambo Tauro
Oct 5, 2015 09:37 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
folivier
Sep 26, 2015 02:28 PM
