Rear axle lube?
Old Jul 27, 2003 | 11:02 PM
roush97's Avatar
roush97
Default Rear axle lube?
What grade of oil am I supposed to use in the rear axle, the same as the differental? I've got a seal out on the left sideand I'm gonna replace it, but the repair manual says to fill it with the proper oil but doesn't say what kind.
Old Jul 27, 2003 | 11:07 PM
Buzzstang's Avatar
Buzzstang
YES YOU HAVE TO REMOVE THE BACK DIFF COVER TO REMOVE THE AXLE TO FIX THE SEAL. MAKE SURE THAT THE AXLE DOES NOT HAVE ANY BURES THAT CAUSED THE SEAL TO LEAK. JUST PUT THE REAR END BACK TOGATHER AND ADD YOU REAR END GREASE/OIL AND DONT FORGET THE BOTTLE OF FRICTION MODIFIER. THE AXLES USE THE SAME GREAR AS THE DIFFERENTIAL DOES. YOU JUST FILL UP THE DIFFERENTIAL UNTIL YOU CAN FEEL IN IN THE FILL HOLE WITH YOUR FINGER.
Old Jul 27, 2003 | 11:22 PM
roush97's Avatar
roush97
Thanks, I thought that everything probably took the same but wasn't sure. I almost forgot about the friction modifier too. I'll have to pick a bottle of that up.
Old Jul 27, 2003 | 11:28 PM
Buzzstang's Avatar
Buzzstang
YES THAT STUFF IS A LIFE SAVER!
Nov 10, 2015 11:39 AM
firecoyote
Sep 27, 2015 02:37 PM
PB Pod
Forum Issues and Feedback
Sep 17, 2015 08:32 PM
Sep 10, 2015 08:39 PM
Dragonus18
Sep 9, 2015 01:21 AM
