help! cooling problem... 95 cobra
Old Jan 23, 2007 | 04:30 AM
POIZNES's Avatar
POIZNES
Default help! cooling problem... 95 cobra
hey guys i need some input... i have a 95 cobra that i havent really drove in 3 years besides about once a month to keep the fluids and battery moving! today i had it running at a gas station and noticed it was leaking antifreeze out of the radiator cap... the guage says its running cool and takes forever to even get close to warm, im thinking there may be some kind of blockage... any suggestions would be great! thanks men
[IMG]local://upfiles/58575/11930EC4C5FA4FA5B2FB6A257081F2E6.jpg[/IMG]
Old Jan 23, 2007 | 04:40 AM
MustangMike2001's Avatar
MustangMike2001
Default RE: help! cooling problem... 95 cobra
If it was blocked then it would be heating up really quick and then overheating. Check the thermostat first. Maybe it's stuck open..
Old Jan 23, 2007 | 04:57 AM
POIZNES's Avatar
POIZNES
you think a thermostat stuck open would make it build pressure and leak from the cap??? thanks for the input!
Old Jan 23, 2007 | 05:02 AM
MustangMike2001
No I think a cap with a bad sealwouldbe the more likley cause of the leak. Have you ever opened a radiator cap on a warm engine? Thats called pressure and there is enough pressure under normal conditons to pass a bad seal. A clogged system would have your engine overheating, not taking forever to warm up. The thermostat stuck open would have the system free flowing and could be the problem. It also could be that your fan isn't cutting off and is running constantly.Good luck.
Old Jan 23, 2007 | 12:25 PM
corvetteguy's Avatar
corvetteguy
A radiator cap should never leak, under any
pressure. You do meen radiator cap not
overflow tank cap? The radiator cap would
open and send prestone through the small
rubber hose to the overflow tank. This happens
every time you drive the car.
Just buy a new cap ($5).
You may not be fully warming up the engine to
get the thermostat to open circulating the fluid.
You need 15 minutes to 30 minutes in cold
weather.
Old Jan 23, 2007 | 02:08 PM
StangChik's Avatar
StangChik
you don't have do be a smart @ss, he's right....if it takes a long time for your car to warm up, whether the cap is leaking or not, you're t-stat could be stuck open. If it were to stick open then yes it could put additional pressure on the cap, causing it to leak. Replace the cap and check your t-stat. If it is in fact bad, at least your car had a fail safe, so it doesn't stick closed and make your car overheat. By the way, when you ask for help, don't get rude and offended when someone answers, no matter if think its wrong or right. WE are only here to try and help.
Old Jan 23, 2007 | 07:51 PM
POIZNES's Avatar
POIZNES
thanks for the input ladies and gentlemen... i will check the cap first thing when i get it back! and it is the radiator cap not the overflow tank cap
Old Jan 23, 2007 | 07:52 PM
POIZNES's Avatar
POIZNES
hey stang chick... nice horse!
BOB ROME
Jul 26, 2023 01:54 PM
Nov 10, 2015 11:39 AM
88 orangepeel notch
Oct 5, 2015 09:03 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
Sparks_88
Sep 8, 2015 01:06 PM
