how to install camshaft
Old Jan 24, 2007 | 02:17 AM
redemption's Avatar
redemption
Default how to install camshaft
can anyone explain how to install a camshaft or give me a link to a site explaining how to install one please
thanks
Old Jan 24, 2007 | 02:10 PM
GreyStang's Avatar
GreyStang
Default RE: how to install camshaft
Back up about 20 feet.. hold the cam in front of you and RUN towards your car! With luck it'll pop right in
What kind of engine are you looking fortheinfo on?
Old Jan 24, 2007 | 08:09 PM
redemption's Avatar
redemption
5.0 86 stang
about a intermediat mechanic
tyrin gto learn how to install a cam now any links or books ?
Old Jan 24, 2007 | 09:10 PM
GreyStang's Avatar
GreyStang
==> Read this <== Something to get you started..
It's a 289 engine, but the cam goes in a similar way.
Old Jan 28, 2007 | 11:37 PM
gspfunk's Avatar
gspfunk
Are you swapping out other parts or just the cam? ...Just curious b/c a cam swap on a stock 302 motor is a lot of work for not a lot of gain. 86 D7 heads or 87-93 E7's will not provide enough airflow. Gt40's will work much better, but may not provide enough PTV clearance (piston to valve clearance) since you have flat top pistons (ASSuming it's an 86 motor).
Remove the U/L intake, valve covers, rockers and pushrods. You'll want to drain the coolant, BTW. Get a telescoping magnet and remove the lifters...put them in an egg crate so you can put them back in the same bore you pulled them from.
The next steps can vary based on who's doing it. Remove your radiator, crank pulley/dampner, and timing cover. Remove the timing chain and you'll have access to the cam. You need to degree the cam properly to avoid having engine/valve timing issues. Replace the cam bearings while you're in there, too.
^^That is a very generic walk through... I would strongly recommend you have someone there that knows what's up or find some more complete walkthrough's!!!!
mtgldr
Feb 3, 2024 09:00 PM
uberstang1
Sep 20, 2015 06:42 PM
BOBCATJACK
Sep 14, 2015 02:18 AM
Sep 10, 2015 08:39 PM
