quick n EZ newb question
Old Oct 9, 2004 | 02:14 PM
Wings65288's Avatar
Wings65288
Default quick n EZ newb question
when you get a dyno test, do they take the whole engine out of your car and how much is it to get one?
Old Oct 9, 2004 | 02:31 PM
OUZBnd's Avatar
OUZBnd
Default RE: quick n EZ newb question
You can get a engine dyno or a chassis dyno. A chassis dyno measures the power at the rear wheels, where a engine dyno measures power at the crank. Prices will vary, but around here it cost about $100 to get a chassis dyno tune.
By the way, it's probably harder to find a chassis dyno than a engine dyno.
Old Oct 9, 2004 | 02:46 PM
Wings65288's Avatar
Wings65288
cool thanks for the help ouz, one more q. do they take your whole engine out or do they just leave it in the car and do the test?
Old Oct 9, 2004 | 03:25 PM
OUZBnd's Avatar
OUZBnd
If they do a engine dyno they have to take the whole engine out. A chassis dyno you strap your car down and the rear wheels (or front if front wheel drive) are on rollers. You run your car through the rpm band and it measures the power that way. So the engine stays in the car in that case.
Old Oct 9, 2004 | 05:01 PM
vfast's Avatar
vfast
I ♥ Acer
*LMAO*..sorry ...I guess some people are in the dark ..no need to pull the engine
Old Oct 9, 2004 | 06:45 PM
OUZBnd's Avatar
OUZBnd
ORIGINAL: vfast
Are you saying you can engine dyno with the motor in the car?
Old Oct 9, 2004 | 10:35 PM
vfast's Avatar
vfast
I ♥ Acer
no....why would you want an engine dyno? what REALLY matters in rwhp right....so go with that...
Old Oct 10, 2004 | 03:07 AM
Wings65288's Avatar
Wings65288
but if you do a chassi test then how can you really officially tune the car? so wouldn't a dyno be more suffecient?
Old Oct 10, 2004 | 10:35 AM
vfast's Avatar
vfast
I ♥ Acer
ok..remeber the "car" to go fast needs to be in tune,what i'm saying is engine,chassis, drive..must be one..to much hp and no supension means your slow vice versa......with a chassis dyno and using Air/fuel meter you can tune the car to it's limit before detnation
Old Oct 10, 2004 | 11:43 PM
Casper98GT's Avatar
Casper98GT
I ♥ Acer
LOL. Im with you Vfast. I cant think of any normal person that would use an engine dyno. Stick to the chassis.
