Blinkers and Heater won't work???
I'm not sure if it's the ingnition or not but the blinkers and Heater won't work anymore. Neither are dead just for some reason when the key is turned alittle it used to turn on. now it doesn't work at all. It's a 1990 Mustang
Do they work when the car is running? Does teh key "click" into position when you turn it forward? You should be able to click it forward to two positions before you crank it to start, at which point it falls back to the second position after it starts.
neither work at all now!! not even when the car is running!! there is no play between the accesory and the car turning off!! if you move the key back just alittle the car shuts off
Sep 1, 2015 08:16 PM
